620 fuel bowl and new lines
I have a new fuel bowl with shutoff to install. I will have to probably make a new fuel line.
What size is it? Where can I get one? local NAPA?
What do you recommend for a bender?
Thanks
(quoted from post at 06:51:26 10/19/21) I have a new fuel bowl with shutoff to install. I will have to probably make a new fuel line.
Thanks
5/16" STEEL brake line should work.
If it still has the original fittings that mate with the line you will need to silver solder steel "glands" to the ends of the line and use the matching nuts.
You can unsolder and re-use the old parts or Deere and aftermarket suppliers still have those parts.
I don't have the part numbers at hand, and archive search should turn up some similar threads that include those numbers.
As to a bender, there's all sorts of choices, for this rather simple project you shouldn't have to buy a real expensive one.
(quoted from post at 09:50:16 10/19/21)
Thanks
Thanks, I have Sil Foss and brazing rods so it should be easy to move the ends over to the new line.
