susandiane
I'm a 2 banger person working on a friend's early 4020-please cut me some slack. On the right side of the engine, the small diameter hoses from the water pump to the heater to the bottom of the pringle's can
like oil cooler, to the block need replacing. A rat ate a hole in one, but they are all groty. The lower fitting on the pringles can tall tube is very corroded. This comes out at a right angle at the bottom facing
forward, not at an angle up and forward as I've seen in some pics. With all the gunk, I can't tell if this is a replaceable hose fitting or pressed into the lower part of the oil/ water cooler (heat exchanger). I
don't want to mess with it until I have a vague idea what I'm doing. Is this hose fitting replaceable and how? Thank you for helping the ignorant! Someday I may be able to count higher than 2, but it's a struggle.
