I am at a loss with what to do with my clutch on my late model B. I can't get it adjusted correctly to engage with any force. I engage the clutch with adjusting nuts loose. I then tighten the nuts and it takes force to disengage it and I here that snap . But when I try to engage it again, it will not engage no matter how hard I push the lever. If I loosen the nuts a few turns, I can get it to engage again, but not with a pop or any force, and just the weight of the lever will disengage it.
i changed the operating sleeve to one with no play in the drive pin hole since I thought that could be my problem. The clutch dogs and toggles and adjusting bolts all look good, but maybe i am missing something here. I don't want to spend the money to replace all those parts if I don't have to, but I am at loss what to do next.
Will having new dogs and toggles and bolts make a difference in adjusting?
