jasonb50630
New User
I recently restored a 630 going completely through everything including the hydraulics.
The three point hitch was working fine with no issues until I decided to use the remote outlets to try out an original cylinder I restored to go with the tractor.
I was working the cylinder back and forth to work the air out of it and decided to work the 3 point up and down and that's when I realized the hitch would not raise. It will hold position but won't raise.
Its like no oil pressure is getting to the 3 point hitch but the remote outlets work fine. Oil level is fine, and pump is on.
Just curious if anyone else has had this happen and what the cause was.
