4430 front end hydraulic leak
T-Nason
I inherited a later model 4430. After I power washed and scrubbed about 10 years worth of dirt off I noticed a slow drip of hydraulic fluid on the front of the tractor. It seems to be coming from right where the tie rods connect? Any idea guys what Im getting into? Is this an expensive repair?
Steering motor. Might be able to slide sheet metal out from under the radiator for a better look. Or Maybe hyd. pump. If pump $1000, steering $150.
