Company Logo (800) 853-2651 Shop Now
Re: JD 320 Ignition question
John T
07-22-2021 04:05:35
I agree with the other fine gents IFFFFFFFF its still the original positive ground ?? - coil terminal receives voltage from the ignition switch being ON while its other + wires to the distributor where it gets its POS ground when the points are closed..
Often a bad coil is one of the last reasons for no spark while burned corroded oxide covered or pitted points are the leading cause. In case you haven't already diagnosed the cause of no spark or checked the points here's a Troubleshooting Procedure
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=5745
John T
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: model 55 JD combine 12 ft complete outside folding grain augar hercules motor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
