I recently replaced the magneto on my 51 Model A and the tractor is very hard to start. It will crank and crank and crank. Blow some white
smoke. Crank. Blow a rafter shaking POP out the exhaust. Crank. Then randomly catch and fire and run. Once running it runs good, fires on
both cylinders, but not great. It is very sensitive to changes in speed/load. I need to feather the clutch just right to move and even
pushing the throttle too fast can kill it. Then the cranking starts all over again. What am I missing? Am I still out of time? Do electric
start tractors with mags prefer spark more advanced or retracted? I assume tilting it towards the front advances it? Carb is clean but could
something have gone wrong in there? Could a component of he mag gone out already?
I'm looking for a direction to go because the tractor just isn't fun to use right now and I use it a lot for tilling, planting, cultivating
and picking in the fall.
Thank You.
Thank You.
