Steve in IL
I wanted to pass this by the experts, to ensure that Ive got this right... Friends Model B runs good, as long as the gas petcock (on the fuel bowl) is turned off (runs until fuel runs out). If you turn on the fuel, it will start (after a few seconds) making black smoke and missing, until it dies. Removing the plugs at this point, the cylinders will be wet with raw fuel.
Thinking its a float issue. it has to do with the float allowing too much fuel in. Could be: 1. Float height setting, 2. Non-floating float (hole), or 3. poor needle valve sealing.
Folks , based on your experience, what do you think? Any suggestions are welcome
Thanks.
Thanks.
