I apologize if this is a stupid question but I have tried searching for an answer and have not been able to find one. I have even spoken to local farmers in my area and could not get a clear answer.
My 4020 has the rear wheels mounted all the way in / as narrow as they can be. The centers are about 1" or less away from touching the square axle housing. I am wanting to know if there is a wheel weight that can be mounted toward the inside that has a large enough hole in the center to clear the grease fitting and square shaped axle housing. My rear tires are 18.4-34 and have cast centers. They do not have fluid at this time. I do already have 2 (140 lb) wheel weights mounted to the outside of each wheel center and cannot add anymore on the outside because they will interfere with my bolt on dual hubs. I would like to add more weight and would prefer to do it with iron if possible and do not want to give up the dual hubs.
Thank you
Scott
Thank you
Scott
