Re: Bought a '59 John Deere 630 - now I need to get i
Dan in Ohio
03-08-2021 10:46:02
I use only grade 70 chain, one on each side of front frame rails and two chains one in each corner of the draw bar frame (not the tongue). Do not attach anything to the front pedestal narrow front or wide front. I have even had a cultivator front bracket on a tractor and two chains hooked to that and been chastised by the people with knowledge of DOT regulations. Believe me if you haul it to a show someone will advise you (whether you want them to or not). You will need four chains and four binders as well a an assortment of clevis's. Not a place to go cheap.
Dan in Ohio
03-08-2021 10:57:20
 Re: Bought a '59 John Deere 630 - now I need to get i in reply to Dan in Ohio, 03-08-2021 10:46:02
You may be pleasantly surprised how easy the wheels will move. I have had both experiences, some are easy to move while others are nearly impossible to move. Find someone with experience to help you, have a good hydraulic jack, wood blocks and every tool you think you might need. Pay someone with a deck over trailer to haul it for you.
