I have had problems with this tractors clutch from day one. This is the second time it has been split. I decided to just put a new clutch in it this time. Everything went together okay this time the fingers were pre adjusted according to instructions. I adjusted the clutch throw fired her up and after fixing one hyd leak checked the clutch. Put it in high and let it out with the brake on and would almost stall the engine. clutch is hard to push but seems to work fine. Now the big one pushed all the way in and engaged the pto worked okay, so I thought. Now when you let out the clutch the drive clutch engages before the pto clutch? What the heck
