Unstyled A Cracked Block
jeffgrosso80
New User
I started removing the head gasket from the block of my 1936 A and found hairline cracks on the gasket side, bottom water jacket spaces. Is there anything to be done to repair this or is it time to look for a different block?
Pictures attached.
Any suggestions are happily welcomed!!
can it be fixed, yes. cant it be used liked that , yes. the surface is pretty rough looking also and should be resurfaced.
Thanks! Is something like this typically welded or sealed somehow? Hopefully local machine shop can clean-up the surface.
I have had several blocks repaired with similar cracks. Resurface the face of the block; drill and pin the crack. Make sure that is the only crack in the block.
