JD Side Shield ID
Bobl1958
Can anyone tell me if this shield on the right is a side shield and if so what does it fit? I thought maybe 4320 but I don't think so. It definately looks factory and not something someone cut up. I have it next to a 4010 shield for size comparison. Thanks a lot - Bob
In looking at the JD parts book for a 4320 with Hinson Cab, I can't see that shield anywhere. Doesn't necessarily mean it's not 4320, but not looking that way. It definitely appears to be factory cut the way it is. Hopefully someone will have the same piece and know. Thanks again for all the help - Bob
If the two panels are same height as they look like they are??, the notched panel is for a factory 4020 cab tractor . The 4320 shield would be taller than the 4010 / 4020 shield. Both right hand side panels. DW
