John Deere Tractors Discussion Forum |
4430 quad shift modification
Author |
[Modern View] |
big roller
02-21-2021 21:28:08
Some years ago I saw a post with instructions on how to modify the shift positions on a 4430 quadshift. It resulted in the 3-4 gears being moved to the 1-2 position and vice versa. Moving the 3-4 gear shift close to the 1-2 reverse gears is much more loader friendly. Then the reverse is the same speed as the adjacent gears (3 and 4) on the shifter (Makes forward and reversing much nicer). Otherwise reverse is way faster then 1 or 2 and you go backwards much too fast. I have been trying to find those instructions again. Is there anyone who can help?
MikeJM
02-23-2021 07:59:45
Re: 4430 quad shift modification in reply to big roller, 02-21-2021 21:28:08
Youll have to check the parts book, but the shifter cam out of a synchro 4630 or maybe a 4520/4620 would work.
MikeJM
02-22-2021 06:43:00
Instructions? I wouldnt call them instructions. But if thats what you want then youll need to procure the top shifter cam from a synchro range tractor and swap that in, hook your linkage back up and you will have effectively switched positions with your high and low range.
big roller
02-22-2021 19:23:32
Re: 4430 quad shift modification in reply to MikeJM, 02-22-2021 06:43:00
Thanks. Will that work for a 4640 quad shift as well?
Tim S
02-22-2021 16:10:37
This is true,, years ago Deere sent me the wrong cam,, after I got the job back together the shift pattern was switched,,after I saw what happened I had to go back in and switch the cam,, which I did down through the cab floor,,not fun but it can be done..
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
1967 Ford 3000
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
