I am replacing the hydraulic pump supply line that runs down the LH side frame on a 1971 JD 4320. I am trying to figure out how the R43479 rubber isolator/grommet is installed. If I put it like it is shown on the parts listing picture it will do nothing and I can't really tell where/how it is supposed to be located. If you have an original 4320 and could get me a picture of this area that would be great. It should be pretty visible from underneath the tractor. I think this isolator goes somewhere in the area where the line drops down from inside the upper part of the side frame and then runs on the bottom, lower side of the side fame.
Any help would be much appreciated!
Thanks!
Thanks!
