rear axle ratio
One fellow told me the axle ring gear count is 57 teeth on both 4010 and 4020. What I'd like to know is if the pinion counts I have are correct. If the 4010 has 18 teeth, with 57 ring gear ratio would be 3.165-1. If the 4020 has 15 pinion teeth, with 57 ring gear ratio would be 3.799-1. Anyone have each axle apart to get an accurate count?
