oldcartech
New User
GREETINGS TO ALL!
I bought a 1943 slant dash "A" with the hood/gas tank off and the cylinder head off. Now I'm to the point of installing parts that I did not remove. The problem I'm having now is connecting the 3 way fuel valve to the rod that is used to turn the valve. The governor is blocking a straight line between the 3 way valve and the opening in the dash for the rod. As it is now the 3 way valve would have to go up about 1" to clear the governor. The rod was not included in the parts I received so I am using a straight rod from the hardware store. I can fabricate the part that connects the rod to the 3 way valve.
It is an aftermarket 3 way valve but holding it up besides the original it looks to have the same dimensions.
Does anybody have good pictures of the 3 way valve with the rod installed, especially as it goes over / around the governor? I'm beginning to think this tractor has miss matched parts.
THANKS!
THANKS!
