backyard mechanic
Could use a little help if anyone has had similar issues
and fixed or replaced one of these assemblies.
The manual says the check valve assembly should not be taken apart unless a new assembly is to be installed.
So, not sure if a new assembly is even available or if there is another remedy. Source for used or aftermarket parts ?
This unit has been used a lot over the years between snowplowing
and log hauling so probably just a worn out check valve. Lots of ups and downs over the 30 yrs I've had it..
Any help appreciated.
