kidroc2133
New User
Just joined the forum and have found a lot of good information before joining, but I am at a loss on this tractor I bought. It was rebuilt then sat for 5 years before I bought it (300hrs on rebuild). I can not get it to stay running. The injector pump is working fine. I get fuel to the injectors. Fuel filter replaced, new injectors, new starter, fresh diesel. Timing was to be said an issue with it when I bought it so the timing was rest with #1 at TDC and the injector pump timing marks line up. If I use either I can get it to run but after a few minutes it will start to die down and shut off and when I get it to run its at higher rpm than what it should be but anything less and it will die. Return line checked and not clogged. I am at a loss and need some your advice to help me get this thing running right. Thanks.
