Company Logo Shop Now
John deere 4040
Redman1888
01-12-2021 18:36:13
I recently bought a 4040 with a m&w turbo kit! The pump is a roosa master rotary pump. Has anyone ever turned the pump up? It's still set at factory settings. Thanks
ejr-Ia.
01-14-2021 15:48:34
 Re: John deere 4040 in reply to Redman1888, 01-12-2021 18:36:13
their is another way need to turn the leaf spring tighter you will find it after you take off the top of the pump 3 screws mater of tacking throttle linkage out in the bottom back a small hole to stick a Allen wrench down the hole to turn the screw tighter on the leave spring half a turn might be enough.You may need a book to do it.
Dieseltech
01-12-2021 19:26:08
StanadyneRoosa/Master pumps on most JD applications need torn down to remove the shims behind the leaf spring if still in place. Shims were installed to prevent turning max fuel up from outside.
Dieseltech
01-12-2021 19:32:11
 Re: John deere 4040 in reply to Dieseltech, 01-12-2021 19:26:08
The shims were used on two roller pumps. If you have a DM4 pump it needs to come apart so the rollers can be set correctly on the centrality gage. If not set evenly there's a risk of head/rotor seizure.
4240 Turbo
01-17-2021 08:53:20
 Re: John deere 4040 in reply to Dieseltech, 01-12-2021 19:32:11
Yeah, the shims prevent any real adjustment. I have turned these up slightly and makes a difference if you can get a 1/16-1/8 turn from both screw heads, and they become pretty smoky. That mw turbo seems to be almost too small on my all my applications to really handle a fuel up condition, but you can get some gains with them.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
Latest Ad: 560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
