Company Logo Shop Now
HELP - 6x4 Backfiring and No Start
afavia
01-12-2021 06:43:28
I purchased a 1998 JD 6x4 with Kawasaki FD620D Liquid Cooled engine that will not start and only backfires through the carb when starting attempt.
I have completed the following:
1. Compression tests show 175/180
2. Flywheel rotated to TDC on each cylinder and valves adjusted to 0.010
2a. I made sure of TDC with a screwdriver in the spark hole.
3. All push rods and rockers checked and confirmed ok.
4. Valves and rockers operate as should with starter motor, cam gear must be ok.
5. Spraying starting fluid in carb or directly in intake only can achieve a backfire through carb / intake
6. Spark / Fire tested and successful at each plug. Verified against block and with spark plug tool.
7. Fuel verified and confirmed at carb. Electric Fuel Pump.
Next Steps I am planning:
1. I ordered new spark plugs (NGK BMR2A)
2. I ordered a new carb
3. I will clean out the spark arrestor and muffler.
4. Planning on pulling the flywheel and checking woodriff key.
I am honestly stumped on this. I have good air, fuel and spark. I have tried with choke, air filter removed, carb covered with hand, spray, etc. Also, the oil is overfull and thin but clean and correctly colored. Possible fuel in gas tank from starting attempt too many times without firing?
Any help would be appreciated.
afavia
01-18-2021 07:14:17
 Re: HELP - 6x4 Backfiring and No Start in reply to afavia, 01-12-2021 06:43:28
I was able to remove the flywheel with a harmonic puller. To my surprise the woodriff key is actually a part of the crank and not seperate? I cleaned everything up and took the opp. to replace the plugs and again re-seal the carb with new gaskets and gasket sealer. It fired up! I have no idea what I did to correct this issue, as nothing else was really improved or changed?
K Effective
01-13-2021 12:23:43
Flywheel is just taper fit to the shaft. A pry bar can take up the small amount of thrust in the crankshaft, then tap on the crank end with a brass hammer, or I have seen an air hammer used. The flywheel should pop right off, as long as there is just a little space for the crank to move away from the seat. Try to get the pry force as close to the center as possible.
If you can clean the end of the crank really well, you might be able to see the keyway cut in it and compare to the keyway in the flywheel, but not always.
gbs
01-12-2021 17:11:35
neighbor had the same problem with a 14 hp briggs, he said when he was trying to start it his mother who lives next door called to find out what all the shooting was about, found out it had sheared the flywheel key was his problem, unlike the point type ignition an electronic ignition will still fire with the key sheared.
Dan in Ohio
01-12-2021 08:56:00
Your gator started getting the steel cam gear starting with this engine and serial number in Feb of 1998, FD620D-ES11 – Beginning serial 152490 – John Deere Model 6×4 Gator, if you still have the plastic cam gear that is where I am putting my money.
David G
01-12-2021 07:56:42
I would "assume" that valve timing is good based on your compression numbers. I would leave the fuel side alone for now. If multiple cylinder are you sure plug wires are not crossed?
David G
01-12-2021 07:18:04
Your timing is off, remember there are two TDC's.
When did it run last?
afavia
01-12-2021 07:38:00
 Re: HELP - 6x4 Backfiring and No Start in reply to David G, 01-12-2021 07:18:04
I am starting to think the timing is off as well. However I can believe the cam gear has any problems as the valves are operating as intended. Yes, I rotated to TDC 2x and set gaps on valves each time. What else could be throwing the timing off? I checked TDC on the flywheel and confirmed with a screwdriver in the plug hole to verify that the flywheel was not off.
Jd man wis
01-12-2021 12:59:25
 Re: HELP - 6x4 Backfiring and No Start in reply to afavia, 01-12-2021 07:38:00
I also would say that the key in the flywheel and crank are sheared and throwed the timing off that where I would check.
afavia
01-13-2021 12:05:18
 Re: HELP - 6x4 Backfiring and No Start in reply to Jd man wis, 01-12-2021 12:59:25
I went to oreilys and rented two (2) jaw pullers, however the 1st one (5-ton) was too small for the flywheel, and the 2nd one (7-ton), the metal was too think to fit behind the flywheel and the block. Anyone have a trick to get the flywheel off without using a hammer and pry bar?
Today's Featured Article - Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains? ... [Read Article]
Latest Ad: Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
