Company Logo Shop Now
Check valve questions again
svcummins
01-11-2021 14:00:42
When drilling the fitting am I supposed to drill to a depth of .650 ?
Tx Jim
01-12-2021 03:47:06
 Re: Check valve questions again in reply to svcummins, 01-11-2021 14:00:42
svcummins
01-12-2021 17:57:12
 Re: Check valve questions again in reply to Tx Jim, 01-12-2021 03:47:06
Thanks it all makes sense now . I just hate dropping something off with no idea what needs done
wore out
01-12-2021 03:42:01
That's the depth to which you run the tap down into the fitting.
I suspect you can get by with the lesser depth if using a bottoming tap to finish vs. using a "plug tap".
svcummins
01-12-2021 17:55:39
 Re: Check valve questions again in reply to wore out, 01-12-2021 03:42:01
That makes sense . Now I just need to get it off and take it up and let them do it . The dealer is sending a copy of the service bulletin then I can take that with the parts
wore out
01-11-2021 21:34:46
The instructions in your first post make perfect sense to me and you say you are having a machine shop guy do it, dunno why there'd be any issues, IMHO.
svcummins
01-12-2021 01:41:41
 Re: Check valve questions again in reply to wore out, 01-11-2021 21:34:46
Where do you find anything that matches up with .650 or . 850?
svcummins
01-12-2021 01:32:19
I’ve had the shop do quite a few little jobs like this and they are cheaper than buying the bit so that’s where it will go
Cliff Nelson
01-11-2021 20:39:50
I drill them all the way to the intersecting hole as the original service bulletin states. Tap deep enough for the valve seat to thread in to the shoulder.
svcummins
01-11-2021 21:16:45
 Re: Check valve questions again in reply to Cliff Nelson, 01-11-2021 20:39:50
I just ask my dealer if he had any instructions
wisconsin cowman
01-11-2021 14:38:22
I would think you would have to drill deeper then .650” because he has the hole tapped to the depth of .650".
svcummins
01-11-2021 14:45:25
 Re: Check valve questions again in reply to wisconsin cowman, 01-11-2021 14:38:22
I’m going to take it the machine shop hopefully he can figure it out
wisconsin cowman
01-11-2021 14:58:17
 Re: Check valve questions again in reply to svcummins, 01-11-2021 14:45:25
He probably drilled it about a 1.00” if he stopped at .200 and tapped it .805”. Going by his numbers he has typed up.
svcummins
01-11-2021 15:15:02
 Re: Check valve questions again in reply to wisconsin cowman, 01-11-2021 14:58:17
The valve measures .769 diameter so that doesn’t fit .850 either . I’m not doing the work anyway
svcummins
01-11-2021 15:05:14
The valve measures about an inch and 410 thousandths so I don’t know what the numbers are he has . I don’t have a drill press or a bit
Today's Featured Article - Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains? ... [Read Article]
Latest Ad: Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
