Don Ober
Hoses that I see online here ( the parts department) show them listed as for 1010D is there a difference for the Gas model or are they the same size ?
I replaced mine last year and could not find them for a gas. I ended up going to Napa with the hose I removed and bought something off the shelf that was the correct ID and OD. I want to say it was for a Ford SUV and had multiple bends in it. I just cut out what I needed and have saved the rest for projects. I want to say I spent about $28. My local JD was not helpful on this at all and were the ones who told me to try Napa.
This was for a 1010 RS Gas.
Yes having the same results I was trying to put a heater in the bottom hose, matchted the hoses but found the Kats heater is 1/4 inch too long to fit in the area neaded , So back too the drawing board. Anybody got an ideas??
(quoted from post at 20:38:38 01/04/21) Yes having the same results I was trying to put a heater in the bottom hose, matchted the hoses but found the Kats heater is 1/4 inch too long to fit in the area neaded , So back too the drawing board. Anybody got an ideas??
A few days ago, a fellow posted a couple pictures of his 1010 crawler, on jdcrawlers.com Early Models Board, of how he mounted a tank type heater and the hoses. You might take a look at his pictures for an idea on installing a tank heater on yours.
Ya put a tank heater on, all the bottom radiator heaters will not work. Not enough room between engine and radiator for that type of heater.
I am the individual that posted pictures on JD crawler forum. I have the parts manual that shows the tank type heater and all the parts needed. I can email you the pictures and page with the factory parts for the tank heater
(quoted from post at 02:37:20 01/11/21)
Reading his posts again, it sounds like his is gas. Looking in the parts catalog the head and water manifold are different. He may have a plug in one or the other he could remove to return the heated coolant through, without needing to make an adaptor as you did.
