Bolt torque specs 47 JD model D
Tnbshr
Good morning,
Im looking for bolt torque specs for a 47, D tractor. I have 3 versions of the IT manual but no bolt torque specs. Any help would be appreciated.
Info from service manual.
I run the Connecting Rod Bearings at .0015 > .002 clearance
Crankshaft THRUST is maintained by a CUP WASHER with shims between the CUP washer and the END OF THE CRANKSHAFT.
"NOT a JD factory design"......however as an owner.....:)
Fly wheel bolts are upgraded to GRADE 8 Bolts..
Bob..
(quoted from post at 10:28:29 12/29/20) Info from service manual.
Bob..
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69147.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69148.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69149.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69150.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69152.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69156.jpg">
Thats great info. Thanks! Do you know what you do main bearings at?
The service manual.... Connecting Rod bearing running clearance ... .002 >.004 clearance
I run the connecting rod bearing clearance at .0015 > .002 (that's after, I have checked the Connecting Journals with a Micrometer and Plastigage)..
The service manual ...Main Bearings running clearance.... .002 > .006
Bob..
(quoted from post at 11:06:35 12/29/20) The service manual.... Connecting Rod bearing running clearance ... .002 >.004 clearance
Bob..
Hi Bob,
Do you know what you tighten the main bearing bolts too?
A few more torques I had in my book - head nuts-208ft lbs - rod nuts-100+cotter pin - main nuts 100+cotter pin - block 90 make sure all tight, cause block carries quiet a load. Flywheel 275 ft lbs..
(quoted from post at 11:30:14 12/30/20) A few more torques I had in my book - head nuts-208ft lbs - rod nuts-100+cotter pin - main nuts 100+cotter pin - block 90 make sure all tight, cause block carries quiet a load. Flywheel 275 ft lbs..
So the cylinder block nuts to the crankcase are only 90 ft lbs?
They are huge 7/8 studs but perhaps thats for the weight of the tractor?
Ya, I think the block nuts torque should be more, your right?? On your D, what size socket fits nuts
on the block studs?? I don't think the studs are 7/8 inch??
(quoted from post at 06:57:35 12/31/20) Ya, I think the block nuts torque should be more, your right?? On your D, what size socket fits nuts
Your correct the studs are 5/8" and the nuts use a 1 1/4" wrench.
I shouldn't go by my memory anymore!
Quote:
Your correct the studs are 5/8" and the nuts use a 1 1/4" wrench....?????
With all do respect.....see pic below.........
Bob..
(quoted from post at 12:43:18 12/31/20) Quote:
Bob..
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69482.jpg">
Big nuts? I assume to spread out the load over a greater surface area?
(quoted from post at 21:24:35 12/31/20) Info for Styled "D"
Information from PC-RD1
Bob..
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto69578.jpg">
Sorry bob you lost me somewhere. We were discussing what to tighten the cylinder stud nuts to, how many ft/lb with a torque wrench? Your info is great and appreciated
Good morning Tnbshr .
The Studs as well as the NUTS that attach the "Power cylinder BLOCK" to the Crankcase are "3/4" NC"...NOT 7/8 or 5/8.
The Studs as well as the NUTS that attach the HEAD to the block are "3/4" NC"...
The torque setting I used is NOT a JD supplied Specification, but rather an Engineering supplied recommended torque.
I considered the GRADE of the STUDS at GRADE 5 given the vintage of the equipment......possibly I'm incorrect on the Grade...????
200 FT lbs Torque has NOT created any concerns on the three styled "Ds" I own....
All the best in 2021.....
Bob..
