farmerjim72
Got my dads 620 running the other day and quit after about 6 minutes of running it locked up tight come to find out it’s locked in the bearing behind the flywheel. We have it pulled apart to the point of the block and rods pistons are out and the fly wheel off just trying to see how you get the bearing and housing out of the end or do you have to pull the whole crank out first and the drive the housing out. Did a 730 diesel a few years ago and were able to just replace the bearing on the ends without pulling the crank. Any help would be great. FYI it sat for 25 years after the cows left do to a radiator leak and we fixed that part.
