burnsg2003
As recommended in an earlier posted I used a jumper wire on the solenoid of my 2640 and I actually was able to start my tractor. So based on
what I had read and the replies I had in an earlier post I felt it was the solenoid so I put a new one on the starter. Turn the key still
nothing happens I turn the key no clicks not nothing. I Know I have a starter that works a solenoid that works the only thing that is left
either the safety switch is bad or the ignition switch is faulty or I have a broken wire. My question is if the safety switch is not working
would the tractor start by using the jumper wire on the solenoid. IS it possible that the ignition switch just went bad. Any more suggestions
that anyone has would be appreciated. Is there a way to test the ignition. Thanks for the help.
