I am starting to change the seals, etc. on my 1969 1020. I have included a picture of what the situation is right now. As you can see there is a very thin shim/washer on the shaft located right next to the tractor housing. Viewing the tractor housing itself reveals a very distinct wear mark on the housing toward the front of the tractor. I have to guess that additional shims or thicker shims should be placed on the shaft between the tractor housing and the 3 point arm. Are these special shims or can I just fit some appropriate washers there?
Thanks,
Tom
[/url]
Thanks,
Tom
[/url]
