Hotflashjr
- Location
- Western MA
Ok with a voltage meter with the tractor at rest and switch off at the
battery I get 12.6. When running at medium to high idle I get a
reading of 14.5 at the battery and 14.6 at the one wire stud off the
alternator. So the alternator is charging. I have the ammeter hooked
up per the instructions from Agri-Service but am guessing I might
need to swap one wire from positive to negative post to make it read
correctly. Prior owner had cut out and removed the voltage regulator
and cutout, if there was one, and had a two wire alternator with
external ceramic resistor.
