prairieplow07
I am working on a JD 4020 LP. We installed electronic ignition, used resistor plugs (gapped at .015) resistor plug wires, rewired the tractor, tried 2 new coils, new ballast resistor (because someone put a different ignition switch on the tractor without the built in resistor), cleaned the fuel filter and still cannot get it to run right. The tractor starts fine but after about 45 minutes it starts cutting out and sometimes dies. We took the electronic ignition out and replaced with new points and condenser and had the same issue. We re-installed the electronic ignition. Earlier new valves were put on the tank. An alternator kit was put on the tractor so it has plenty of charge.
Any thoughts on what is causing the tractor to cut out and miss after about 45 minutes?
