Company Logo Shop Now
John deere 4010
burnsg2003
09-15-2020 18:39:10
I have a john deere 4010 some how when I was bush hogging I seem to have twisted the pto shaft can this be replaced from the rear or will it have to be split. Any comments appreciated
Tx Jim
09-16-2020 06:14:33
 Re: John deere 4010 in reply to burnsg2003, 09-15-2020 18:39:10
When installing shaft utilize loc-tite on bolt threads
Tx Jim
09-16-2020 06:06:06
4010 RC=rowcrop with 6 cyl engine 80 pto horsepower
4010 CUT=compact utilty tractor with 3 cyl 14 pto HP
burnsg2003
09-16-2020 17:29:55
 Re: John deere 4010 in reply to Tx Jim, 09-16-2020 06:06:06
Mine is the row crop with 6 cylinder diesel
Tx Jim
09-16-2020 03:37:26
4010 CUT or RC?
I highly recommend to loosen cutter slip clutch if applicable or acquire/utilize correct driveline shear bolt.
4010 CUT will require a trans split.
4010 RC pto shaft repair procedure would be determined where twist is located. If twist is at stub shaft unbolt 4 bolts then R&R shaft. If twist is located in different location a trans split would be required.
burnsg2003
09-16-2020 05:48:44
 Re: John deere 4010 in reply to Tx Jim, 09-16-2020 03:37:26
The twist is on the outside on the splined shift it. SO if I am understanding correctly I can unbolt it at the back an replace basically the splined shaft. Not sure when you refer to RC what that means. Thanks
svcummins
09-15-2020 19:49:44
Should be able to just unbolt it .
Copyright © 1997-2020 Yesterday's Tractor Co.
