dickwalhout
New User
Just bought a late model JD B. Drove it 3 miles to pressure wash at the dairy and one time the tractor "seemingly" slipped into neutral. Clutch was still engaged, transmission in 6th. I thought it either slipped out of gear or the clutch somehow disengaged. But no, clutch still solidly engaged and when I tried other gears, none of them worked either when I put in gear and engaged clutch. I tried the PTO lever and yes PTO turned as it should. I then put back in reverse, I think it was, and it worked normal. Tried other gears and everything worked normal. I did my pressure washing and then drove the three miles back home without any more issues. WHAT DO YOU THINK COULD HAVE HAPPENED????
