just put a input shaft in my 1969 450 jd dozer. Used it for 3 days with an issue. Today I shut it off and came back 2 hours later. It won't move. Checked pressure and nothing. I dont think the input shaft broke again cause the pto for wench works and that gear is driving with the input shaft. I checked the roll pin inside the housing and its fine. Could the roll pin inside the tranny which is on the same rod have broke? Woukd the pump just go when I shut it down? I'm confused as hell...
