Replacing oil pipe on 4430 2 speed
I see my manual shows G that I have not seen. Any advice. I was trying to leave 2 speed on and replace pipe. Havent seen g and cant determine if it is still in housing. Thanks!
Its a later model and I found out spring and I found out spring and ball are behind control valve. Since I havent taken control valve out, it would not be in the pipe as I interpreted manual. Learning as I go.
