I have a 51 B with electric start. Has anyone ever had a problem before with the starter linkage not sufficiently engaging the switch on the starter? The starter and starter switch are recently replaced, so I know there is no issue there. The problem is that when you press the push button down, it will bottom out on the flywheel cover before engaging the starter. It did not seem to do this when the flywheel cover was off, maybe there is an interference between the linkage and the flywheel cover?
Just wondering if anyone has run into this issue before or has any advice.
