Yes I know oil leaks here are a common as common problem on all JD tractors that use this system, but since I never use draft control and the parts to repair the leak on the 4250 are stupid expensive (the hardened bushes are not available as individual items and must be bought pressed into an assembly #AR103729, and on top of that aftermarket parts are not available in Australia.
So can I just remove the whole shaft and plug up the cast iron bosses that hold the hardened bushes and leave it at that?
Or does the load control shaft also act to provide support for the three point linkage arms so can not be removed.
