(quoted from post at 21:00:59 08/05/20) Can isolate just one scv on this tractor
(quoted from post at 09:38:33 08/07/20)
Still doesn t explain why the pump isn t making any pressure
(quoted from post at 14:45:16 08/09/20) I ordered a plug to change the valve and it didn t work I can
feel the oil and hear it bypassing the valve and the valve gets
so hot after about 5 minutes you can t touch it so I know it s
bypassing even though it shouldn t but the valve is 50 years
old so it could have an issue at the end of the day even with
the valve leaking it still works better than it did when hooked
up to the tractor scv .
(quoted from post at 21:41:46 08/11/20) The plug they sent me didn t have a seal it s just more of a
cap so maybe it s not the right thing but it s what the farmhand
book showed
(quoted from post at 12:19:25 08/14/20) Cannot get a plug from gresen . Going to see if farmhand can get one if not Bomgaars has a 2 spool valve thats rated 30 gpm and 3000 psi
