Replaced the transmission pump
SVcummins
Today . Orings looked good quite a bit of wear on the pump cover and the gears get to take the top back off because I didn’t get the arm for the 3 point in the right spot . hydraulics still aren’t working like they should . Time for bed try it again tomorrow I guess
Went out and checked the oil again hydraulics probably would work better if the oil was on the stick ? Better go to bed while I’m only this far behind
If a new pump was not available . A wee bit of flow could be restored by grinding all the gears and the cover flat. Then taking a little off the pump body to restore side clearances. The replacement pump for my tractor is a higher flow upgrade.
