John deere 3 pt backhoe
Hello
Can anyone tell me what model 3 pt backhoe I have?
I can not find any stamping or markings ?
Thank you
Deere was big on having sub-frames on most all little hoes even back in the 80's, and having the single cylinder chain swing limits it more, I'm guessing its a Woods or a Bradco painted green. most all of them had the ID/serial# tag on the main frame
Jim, Looking at the swing post and control levers, I think you got it right. I had forgotten all about the 165 when I was going through my parts CD’s
I am not up to speed on 3 pt backhoes.
This one has a "L" or a lip of steel hanging over the main trunk that comes off the pivot point.
99 % of the pictures online I see - DON'T have this.
There are a couple of sins on it I will need to clean up, but its all there and does work.
Thanks to ALL
If you can find the sub-frame mount . You will wonder why anyone fiddle twits away with the three point hitch backhoe .
Looks exactly like a 165 I just bought. I need the closed center plug for the SCV and am having trouble finding it. What is yours mounted on?
(quoted from post at 22:36:15 01/25/21)
ssues
To be correct in your search, You need the closed center plug for the backhoe control valve. The scv (selective control valve) controls the oil to the the remote couplers on the rear of the tractor. They are two entirely different valves.
