Jd 322 skidsteer
This probably isn't the place to ask but I thought I'd give it a shot I have a deere 322 skidsteer on tracks I'm trying to figure out what hydraulic oil it uses and is it the same oul the drives run in or does the drives take a different oil thanks
I use HyGard in my 320 skid hyd. Manual will have the answer to your other question. Mines not close by.
You really need a copy of John Deere's Operator's Manual for your machine. The publication number is OMT215996.
The 317 and 320 use the same Technical manual as the your CT322, according to the JD publications website. There is a copy of the Operator's Manual for those machines on line, here is a link to it. http://manuals.deere.com/omview/OMT205050_19/OMT205050_19.htm
That manual says John Deere Plus-50 (various weights based on temperatures) is preferred and John Deere Torq-Gard is also recommended. It appears the hydraulic and hydrostatic oil are the same reservoir. I expect the CT322 has the same recommendations. Again it would be best to get a copy of the correct Operator's Manual for your CT322.
I don't have it. You can search for it as I would have to do. Here is how I found the other one. Click on this link to go to the John Deere technical publications for construction equipment. https://www.johndeeretechinfo.com/
Put 27CZTS (no spaces, all caps) in the model box and then click the search icon. That should bring up all the manuals and videos available that relate to the 27CZTS. Write the publication numbers down for the manual(s) you want.
You can use the publication number to do a search on line for that particular manual. You may or may not find one free on line. With the publication number you can also search eBay and other places for manuals to purchase and be sure you are getting the right manual. You can purchase the manuals from the John Deere site as well.
