Company Logo Shop Now
3010 load sensing shaft and retainers
jd4440
08-01-2020 16:00:53
I lost load sensing shaft retainer and shaft slid out losing oil. Before I could replace retainer I was mowing hay and shaft slid out. Special retainer bolts still in place. What do I need to do to keep retainer in place. Maybe a strap bolted to the wishbone to keep retainer in?
Cliff Nelson
08-02-2020 05:47:38
 Re: 3010 load sensing shaft and retainers in reply to jd4440, 08-01-2020 16:00:53
New bolts and retainers. Do not use a lock washer on the bolt so the bolt goes into the retainer farther. As others said, shim the wishbone.
Hay maker2
08-02-2020 04:29:01
Side to Side play in the "wish-bone". It needs to be shimmed so the caps stay in there as when the wish-bone is pushed from one side to the other side it pushes the caps off. And yes, Deere sells a shim kit for that.
jd4440
08-01-2020 16:03:25
tomstractorsandtoys
08-01-2020 19:52:35
 Re: 3010 load sensing shaft and retainers in reply to jd4440, 08-01-2020 16:03:25
Did the same thing to my 3010 thirty years ago. We tack welded the retainer to the wishbone. Tom
Copyright © 1997-2020 Yesterday's Tractor Co.
