Company Logo Shop Now
Wheel weight help
eboor1995
07-31-2020 18:17:14
I found these weights and going to look at Sunday. Are these the correct weights for my 1943 JD B? I have pressed steel centers. Are they the starter weight?
Thanks
dan_41jdh
07-31-2020 18:46:46
 Re: Wheel weight help in reply to eboor1995, 07-31-2020 18:17:14
Yes. D2628R is the starter (or inside) weight for pressed steel wheels and is intended for your "B". This application is shown in the AC-1000 catalog, "Attachments for John Deere Tractors and Engines".
eboor1995
07-31-2020 19:06:28
 Re: Wheel weight help in reply to dan_41jdh, 07-31-2020 18:46:46
What number is the outer weight?
Thanks
eboor1995
08-02-2020 14:32:44
 Re: Wheel weight help in reply to eboor1995, 07-31-2020 19:06:28
How many pounds are the D2628R weights?
dan_41jdh
08-02-2020 15:22:24
 Re: Wheel weight help in reply to eboor1995, 08-02-2020 14:32:44
According to the AC-1000 catalog, the D2628R weights are 150 LBS apiece. This probably includes the fastening bolts since the Master Parts Index says D2628R is 147 LBS. AC-1000 says the Auxiliary weight is 142 LBS each. Interestingly, the MPI states the Auxiliary weight is 147.70 LBS.... Anyway, they're obviously somewhere in that range.
eboor1995
08-02-2020 15:26:39
 Re: Wheel weight help in reply to dan_41jdh, 08-02-2020 15:22:24
Thanks I just bought the two D2628R weights. Are the Auxiliary weights hard to find?
dan_41jdh
08-02-2020 21:01:00
 Re: Wheel weight help in reply to eboor1995, 08-02-2020 15:26:39
I don't know, and I'm definitely not an expert about weights. A person who is doing research about Deere weights is not certain there is a true "Deere" D2381R auxiliary weight exists - he suspects it may be Deere's number for the F&H W-162 auxiliary weight, which are quite common. F&H originally furnished weights for Deere tractors (as well as spoked wheels), and F&H made a starter (inside) weight with a cast-in part number "DP2628" along with their F&H logo. It would be interesting if anyone knows about the existence of a weight with a "D2381R" cast-in part number...
dan_41jdh
07-31-2020 19:31:40
The outer (auxiliary) weight has casting number D2183R.
Copyright © 1997-2020 Yesterday's Tractor Co.
