Company Logo Shop Now
Tranny
John Bates
07-30-2020 18:50:11
just changed hydraulic pump in my 69 JD 450 dozer. Was wondering if there was a way I have to prime it? Just wanted to know before I fire it up tomorrow
Jim.ME
07-31-2020 06:13:26
 Re: Tranny in reply to John Bates, 07-30-2020 18:50:11
That is the H-L-R (transmission)pump. If you put some lube on the components as you assembled it, it should pick the oil up and be fine.
John Bates
07-31-2020 11:07:44
 Re: Tranny in reply to Jim.ME, 07-31-2020 06:13:26
thanks jim. Yes I did that
Jim.ME
07-31-2020 03:23:00
You have been posting about working on the transmission and transmission pump. Did you change the hydraulic pump, located under the radiator, as well? If you lubed the transmission pump when you assembled and installed it; it should pick the oil up if it is correct. If you are talking about the hydraulic pump fill the reservoir, located under right side arm rest. The reservoir is above the pump and it will flood the pump so that pump doesn't need priming either.
John Bates
07-31-2020 05:36:11
 Re: Tranny in reply to Jim.ME, 07-31-2020 03:23:00
I'm referring to the pump that the input shaft runs through. Had to replace input shaft cause it broke due to bellhousing bolts loosened up
Copyright © 1997-2020 Yesterday's Tractor Co.
