burnsg2003
I have a John Deere 4010 snycro shift. It seems to shift into all gears decently but will not shift into second gear and 8th gear sometimes you shift it and it grinds but if you take it out of gear and pull the shifter back hard and quick it goes into gear. Some of the other gears you have to do this with sometimes but 2nd gear will not shift at all and 8th will go in if work with it. IS there a linkage the needs adjusted or is this a transmission problem and if it is a transmission problem do you have to split the tractor. Any suggestions or advice would be appreciated.
