JD 6410 hydraulic problem
Jwbmech
New User
Jd 6410 blowing hydraulic hose feeding the hydraulic filter. Replaced filter, checked and washed suction screen, verified that fluid actually flows through filter and up to pump. Tech suggested pulling the lube oil valve as it supposedly sets the charge pressure to the filter. Nothing has solved the problem. Has anyone ran into this issue? Everything works on the tractor, loader, 3 pt etc. Will blow hose after 5-10 mins. Thanks.
