JD 2640 PTO Bearing Removal Issue
markshelby
New User
I am trying to remove the PTO bearing (JD9344) from the bearing housing (R47514) on my 540 RPM single speed PTO to replace the seal. When I remove the snap ring (R47513) holding the outer bearing race in the housing the bearing will move but appears to get hung up right at the snap ring groove. Are the tolerances this tight or am I totally missing something on how to remove this bearing? Any ideas on how to make this work?
