buickanddeere
Was wondering why the there was a sudden appearance of hydraulic oil across the transmission housing and pouring into the ground .
A couple of months ago I had the shift cover off to replace the O’rings and gasket . Everything held tight until this morning .
This “Welch Plug” in the top front of the transmission case decided to pop out . Pretty sure I had the cover on there and the shifter indexed to the valve . Almost looks like the valve pushed the plug out ?
