extremewhitetail
Hi All,
I have a JD 2150 with a TSS/MFWD transmission. The low speed, high speed and reverse shifter seems to be having trouble going into gear smoothly. I go from low to reverse often and shifting gets sticky and grinds sometimes. It doesn't matter if I am setting still or barely moving.
I have looked in the side port and can't find a grease cert. Sometimes when I pump the clutch it shifts smoothly. Any ideals?
Thanks Matt K.
Thanks Matt K.
