pull type or mounted plow for 1949 j d model A
swindave
hey i trying to find a plow to go along with my 1949 model a john deere with a 800 hitch
would you recommend a pull type plow or mounted? i want to stick with a deere plow
what models of john deere moldboard plow would you recommend?
ive just seen a few A tractors with a 3 pt hitch
There were probably 100 model A tractors in this county. None had a mounted plow. Either a #44 or may 3-12 in a model 55.
I do not own a pull type plow since mounted plows trailer easier and are correct for most of my tractors. Although I have had mounted plows on my A and B. How and where are you going to use the plow?
Mounted plows were not intended for the letter series as they were not yet made. You put that weight on back and will make front end light. I would not want a mounted on any of the 46 B, 49 B or 51 A that I had. All with power troll, now a power lift has only up or down, no inbetween.
