2955 loader plumbing
I have been running my koyker loader from the rear remotes, and I'm ready to install a 2 spool control valve in the cab, but i don't know where to plumb it in. Could someone draw arrows on these pics to show me exactly where to plumb the supply and return? Thanks
Welcome to YT
Supply hose for FEL control valve should be attached to orifice in rear of pressure control(priority) valve where plug(key 15) is located. This is the same location that supplies hyd pressure to scv's. Return should be routed to ported hyd filter cover. I've read were people have added port to cover.
L55982 COVER ADD 88.30 USD
Glad to see somebody what wants to route the hydraulics properly .
You will notice that the loader will move much faster . Without shudders and groans now that the front pump is no longer cavitating.
(quoted from post at 07:27:28 07/13/20)
Yes sir you're correct. If you can't locate fittings & the need arises I can furnish you with correct JD part #s for required fittings.
Are they standard fittings or John Deere specific? Would you put a tee at the filter for a drain? Thanks so much for the help by the way.
