Hello, I have a 2010 JD---not sure the year. How do i find the Year" I bought it about a year ago and it would run but needed a water pump. I'm just now getting around to work on it. I have 3 current issues and would appreciate any help. 1. I turn the key on and it will try to crank. i turn the key off and back on nothing. battery is good, cables seem good. i cked wires to the starter--maybe the switch? 2. i have several wires (example -wire from the coil goes where-- maybe to the alternator?) there are like 3 more wires that lost their home. I have no wires going to the alternator and dont know which one goes where. i did google a wire diagram but I'm not technical enough to follow it 3. i cleaned the gas tank, bowl, carburetor and put a new chock cable on it but still no starting--i wonder if one of the wires that is not connected may be the problem. i haven't checked yet if fire is getting to the plugs. i did take the distributor cap off and made sure it had clean contacts. BTW--it did run pretty good when i parked it--the only thing i remember when i parked it --that it leaked hydraulic fluid and the leaver to accelerate didnt seem to give a lot of gas power. thanks for any help --mark
